that sucks!...how about those sites u like to use and recommend?...open it up and look, it maybe like the 2500 or 3500 or the FLU..thats all a 2800 is, a glorified 2500/2700
I have figured it out thanks for the advice LK I did find the files I needed on one of the sites I like just had to spend the extra time searching for it hehehehe. I ended up using a 2700 j-tag file. Works well now.
