What would I have to do to run a 16-17 V charging system, for a Z2
Username: Impala63rag
DD 9512s , Orion d5000
Post Number: 735
I'm getting frustrated because I want my 9512's to get more power. I can't add on another Orion because of the ohm load (could but not efficient). So I want a DD Z2, But in order to reap the benifits, it needs a strong charging system. What do I need to do to get that?
Los Angeles, CA USA
Post Number: 12053
its too much work impala. just go with an amp that does 5000wrms at 14v.
in order to get 16v, you will need an isolator and some 16v batteries.
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1560
y not consider a Z1a instead of a Z2. alot better for daily, but they're around 1200 preordered.
Username: Extrmndor3
IF U HEAR ME... crazydbs.com
Post Number: 4435
the z1 are mor epowerful than the z2 on 14.4v easily 5000 out of the z1 on 14.4 volts...
u can get an adassa warlord for about 1000 that will do clean 5000 wtts rms easily
Post Number: 737
The DD site says 3k wrms @ 14.4 volts. I just don't wanna drop a buch of bread to not be able to hear the difference.
Post Number: 738
What would I need? some 16V kinetiks and a H.O. alternator or two with a voltage regulator.
Post Number: 740
bumpage
Username: Oleg
Santa Monica, CA USA
Post Number: 882
I'm really interested in this, so I'm just posting so I can get notified via email lol
Post Number: 4436
LOOK AT THE TESTING DD DID WITH THE Z1 :-)
4500 RMS AT 1 OHM WITH THE Z1.. ALOT MORE RMS THAN THE Z2 AT 14.4C... HOWEVER THE Z2 WILL CATCH UP AND OUTBUMP IN 18 VOLT SET UP... BUT STILL THE Z1 ITS BETTER AND STRONGER AND EFFICIENT
Username: Nd4spd18
Southeast PA
Post Number: 1483
" The DD site says 3k wrms @ 14.4 volts. I just don't wanna drop a buch of bread to not be able to hear the difference. "
Lol, you don't know much about Z1s huh?
http://forum.soundpressure.com/showthread.php?t=209
Scroll about halfway down the chart
Username: Dakangofkrunk16
Earth
Post Number: 533
Username: Nd4spd18
Southeast PA
Post Number: 1486
bump
Post Number: 744
So you think I'll see a big difference between my orion d5000, and the Z1?
Username: Jblanford
Post Number: 783
impala check out the new dd z1a
Username: Nd4spd18
Southeast PA
Post Number: 1488
Lol yeah that would be about double the power. Of couse you gotta have a monster charging system to run 5kw......
Post Number: 4437
wel dude.. first of all becarufl abotu the z1.... the z1 got defective and runned 1 ohms all day but it smoked at 2 ohms we dont know why.... well dd made new ones supposed to dont have that problem... but who knows they are juzz comming out.. so ill suggest to wait till some reviews...
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1566
new DDZ1a is 5k @ 12v at 1ohm....so you'll see even more at 14v. The original Z1s were rated at 3k, but they were underrated.
The first batch of the original Z1s had sum problems, thats y they had teh gen-2 come out that had all the bugs fixed.
Username: Waterboy2289
Georgia, DiRtY SoUtH ... 2 18 SX w/ ...
Post Number: 234
Impala, if you have your mind set on DD, then the Z1a is the amp to get for your application!!! No Questions Asked.
Username: Oleg
Post Number: 894
JBL A6000GTI - 7400W RMS x 1 at 1ohm
booya
MSRP $6K lol
Post Number: 235
^^^^^^^^^what?
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1571
4 DDZ1a's strapped - 20,000rms @12v (~30k @14.4v)
5200 lol.
Username: Oleg
Post Number: 897
matt, you confused?
Post Number: 236
About the "booya" part, yes I am.
It seemed as if you were cheering because you found an amp more powerful than the Z1a. Am I correct?
If you're talking big power then you should mention the Hifonics XXV Maxximus(10,000w rms @ 2ohm).
Jordan: Are you reffereing to Ronnies system? If so, it is going to be SICK!!!
Username: Oleg
Post Number: 901
i was booyaing b/c i remembered another monster period. yeah, that hifonics is a beast too.
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1574
naw not directly, but yea it will b sick. I was jus statin in general thatd b bad.....
Post Number: 238
damn straight!
Post Number: 745
I asked about that Hifonics Goliath, 5k wrms. I got nothin' but neg. feedback saying that it isn't as efficient as DD. that it doesn't compare to the Z1. IDK, I just wanna give my babies more to feed on. let them run at full potential.
never got an answer on the charging system though. How do I get a 16-17W charging system?
Will a few 16V kinetik's, a couple H.O. alts, and a regulator do it?
What is an isolator?
Am I missing something? Is there more to it than just adding the right bat.'s and alts?
Post Number: 4449
u dont need an isulator an isulator will make voltage drops.... yes u do need a dual alt... and no aftermarket regulator.... u can get full 16volts to the amp by gettin some 6 volt batteries and wire them seres i think im not sure but thats how u do it :-)
Post Number: 746
So its all about the alts, and the bats, is that right?
Post Number: 747
I'm asking because no-matter what you look at, they perform better at higher voltage.
Username: Nd4spd18
Southeast PA
Post Number: 1512
Dude it's not worth it..... the Z1 is one of the best amps out there, bar none, they do 5000+ watts at 14 volts
Post Number: 748
That warlord looked voltage hungry
Username: Nd4spd18
Southeast PA
Post Number: 1513
But what you said is right, you would just need an alt with a 16 volt regulator and a 16 volt battery.
But keep in mind, the alt won't be able to produce as much amperage at 16 volts as at 14, and you'll be no better off than you would be using a Z1 on 14 volts. Like it said before, not worth it.....
Post Number: 749
I'll either buy this Z1 from this guy for a stack, or wait for the Z1a. I prefer DD.
Post Number: 4450
na the voltage its alil powerful than the z1 on 14.4 and up...
if i was you i get 2 ma audio 4000 hk and strap em they do 3500 easily so thats 7000 watts for the price of the z1 :-)
Post Number: 750
"the alt won't be able to produce as much amperage at 16 volts as at 14,"
ahh, wasn't aware of that.
Username: Nd4spd18
Southeast PA
Post Number: 1514
" I'm asking because no-matter what you look at, they perform better at higher voltage. "
Absolutely not true, an amp with a regulated power supply will produce the same power regardless of the input voltage.
Also, many amps cannot handle 16 volts.
Post Number: 751
Would 2 of the ma audio 4k amps strapped, run my 2 x D4ohm. subs @ 1ohm?
Post Number: 242
You cannot strap the hk4000d's if that is what you are referring to Rob.
Impala, is this a daily system you are trying to improve?
Username: Nd4spd18
Southeast PA
Post Number: 1515
" ahh, wasn't aware of that. "
That's physics for ya. If you have the same amount of energy going in (the engine turning the alt pulley), you will get the same amount of energy out. Meaning that when you increase the voltage regulator, you'll get less amperage, and vice versa. You can't magically create energy.
Post Number: 752
I thought they were strappable, isn't that what chad lee did?
Post Number: 753
yes, daily beater.
Post Number: 243
^^^Amplifiers draw less current at higher voltages though, so it may balance out.
Post Number: 754
With two H.O. alts and a bat bank. They would keep up at 16V, right?
Post Number: 244
Well, now that I know it is a daily system I can give you my informed opinion. DON'T DO 16V!
To answer your above question: maybe.
You really need to stop thinking about doing 16v for a daily system. It pointless, there is nothing to gain. There are tons of high power amps made for 14v.
You said you like DD; alright then, get a Z1a. It can do something like 5000w @ 1ohm on 12v. You've got to stop being so thick headed and realize that 14v is what you need for your application.
Post Number: 757
So if I want to run a 14.4V system, A regulator will sustain 14.4V, as long as there is bats, and alts right?
Post Number: 758
I started this venture into higher voltage when I was trying to find a bigger amp for less, but they all wanted more voltage to push more power. Your right, I'll run the 14.4 with a Z1a when it comes out.
Post Number: 246
I guess I should say when I'm referring to a 14v system, it is really a 12/14v system. Your alt output is 14.x volts and your batteries are at 12.x volts. So if you exceed the current output of your alt you will pull from the batteries which will be @ 12v. But no worries since the Z1a in particular doesn't mind low voltages at all.
Username: Nd4spd18
Southeast PA
Post Number: 1518
" I'll run the 14.4 with a Z1a when it comes out. "
Awesome man, thats one of the best amps you can get bar none. I wish I could afford one, lol.
" Amplifiers draw less current at higher voltages though, so it may balance out. "
Which reinforces my point, the 16 volt system for daily is, in most cases, not worth the money/hassle. Also, that's not true if you're trying to get more power from your amp than it produces at 14 volts (and for what other reason would you run a 16 volt system?)
Post Number: 247
"that's not true if you're trying to get more power from your amp than it produces at 14 volts (and for what other reason would you run a 16 volt system?)"
Example of my point:
If you run an amp @ 1ohm on 14v, and then increase the voltage to 16v, the amp will produce more power with less current draw.
It has to do with one of those equations for power that relates current/voltage/watts together.
Post Number: 4451
nab matt u wrong my friend higher voltage it doesnt mean nuttin however12 volt means that the current travels slower than a 14 volt with same current.... thats why amps produce more power at higher volts... but they have to be made to handle such high voltage..
if u get a 300 alt at 12 and a 300 at 16 volt botch alt are going to produce the same. except the the one at 16 volt its gonna make it flow faster...
yes higher voltage its good but dangerous
Username: Th3pwn3r
Post Number:...
Post Number: 1891
Impala I highly reccomend you do run a 16-17 volt setup in your vehicle.It's nowhere near worth the trouble you're going to go through.Get yourself some amps that are rated at 14.4 and be happy.
Username: Th3pwn3r
Post Number:...
Post Number: 1892
"mpala I highly reccomend you do run a 16-17 volt setup in your vehicle."
DOH!I highly reccomend you DO NOT run a 16-17 volt system.
Earth
Post Number: 542
HOMER
Mmmmmmmmmm DONUTS
Username: Th3pwn3r
Post Number:...
Post Number: 1913
^Yea I'm pretty hungry but I don't eat anything fattening :-(
Earth
Post Number: 547
u dont eat donuts?? all the good sht is fattening lol
Username: Spkrman
Chi town, IL U S A
Post Number: 412
16v setups are very useful for daily if you have the space for the batteries...
You have a few options.
Run an 18v battery only setup, and recharge every few days.
Run 16v batts (it'll charge 18-19 volts) and an EXTRA alternator specifically for the batts.
Both are very useful, very practical, and allow you to get tons of power without any sort of light dim or interference with the car's charging system at all.
Building a 12v system capable of the same wattage WILL cost more than an equivelant 16v system.
No reason to be scared of 16v.
Username: Oglejust
Post Number: 1417
good post ^^^
Username: Spkrman
Chi town, IL U S A
Post Number: 415
Btw,I ran 16v in 2005 on an orion 2500d... with 4 8v batts, I only had to recharge every week or so... and that was daily driven. Even at that point, the amp wasnt hitting protect or anything... stil had plenty of juice left.
The batts cost me $280 all together, and the carger was $80 I think. For an "equivelent" 12v system it would have cost at least double... and your still not seeing that extra 16v power.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11899
actually best way to approach this is as follows:
make sure your amps have unregulated power supplies or all of this is pointless.
next, use a battery isolator to run dedicated audio system batteries in the trunk.
get racing batteries designed to run 16 or 20VDC. There are ones that offer that high of an output voltage but still recharge from a 14.4VDC alternator charge by using capacitance and a step-up regulator internally.
this gives you the 16VDC setup for the audio from the batteris, lets them recharge from a HO alternator, and leaves your car's electronics running from the starter battery at 12VDC to avoid damage.
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1597
^^nice. And just where could one get those batts from GW? any brands u recommend?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11901
also note, by using batteries you have to drain down and recharge later without an alternator you stand a strong chance of gassing, which can kill you in an enclosed car cabin.
Also, going from 14 volts to 16 volts isn't that much of an increase. you'll hear maybe a decibel of difference.
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1601
bump while GW is around...answer my ? if u can.
Post Number: 759
wow, that was informative!!! thanks Mark Potts, and GlassWolf.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11909
Jegs or Summitracing.com have the batteries
Username: Safe_cracker
Chicago, IL US
Post Number: 2640
Here is one. It actually uses an internal structure that uses a extra post for 12v. It is a dual voltage battery, just bought one will let you know how it works out...Polo. :-)
https://www.jegs.com/webapp/wcs/stores/servlet/product2_10001_10002_761814_-1
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1610
nice polo. they had sum on ca.com with a 12v post. but said they needed like a 18v alt to charge em, eventho they had a 12v and 16v post.
So those will charge with a HO 14.4v alt?
Chicago, IL US
Post Number: 2645
Dunno but I bought a 16-20V external regulator for my 300A iraggi so basically it is gonna be on roids, lol. I also bought an extra regulator for the alt so I can rewire the internals to work with the external regulator, will be a drop in replacement when I am done. I need this battery to mount under my hood so this is the probably my biggest problem, but all is good...Polo. :-)
