Ghetto Install
Username: Kaprese
Walstonburg, NC USA
Post Number: 84
This dude I know named David decided he didn't want refill so guess what he did....He took the 2 positive and 2 negatives of the 6x9's tied them together and plug them into the speaker terminals along with the speaker wire coming from the amp.HE THINKS THIS WILL GIVE HIS SUBS MORE POWER LIKE A EXTRA 40watts dat the 6x9's
Los Angeles, CA USA
Post Number: 12138
tell him that extra 40watts ain't gonna do jack sh!t. besides he won't even get that extra 40watts.
TELL HIM NOT TO DO IT. IF YOU ARE HIS FRIEND THEN YOU WILL STOP HIM FROM DOING SOMETHING STUPID.
Username: 40hz
N.C. Usa
Post Number: 250
guess he's tryin to ohm the amp down for more power? could work a little i guess.
Username: Th3pwn3r
Post Number:...
Post Number: 1970
Joshua,do your buddy a favor and secretly cut the wires since he won't listen :-)
Username: Carguy
Post Number: 6120
He won't get any extra power. He'll end up blowing his 6x9s cause they are low wattage.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 4154
he didnt hook the 6x9s up. he did worse... he hooked the stock amp that was hooked up to the 6x9s up to the subs, along with his subs amp. i dont know what exactly is going to happen but it cant be good.
