Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 178 Registered: Sep-05 | ok i have a 2 cu ft slot ported box tuned to 33hz. which sub would be the best performing in this box. trying to go sql with this box. here are my six to choose from. all will be on a power acoustik a2400db. 1. Fi Q 2. Fi SSD 3. Audioque sd2.5 4. Alpine type x 5. Soundspinter Rl-p 6. RE SX |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 846 Registered: Dec-06 | how much power does that amp give? |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 847 Registered: Dec-06 | if it is 1400rms (i think it is) ide get the Q |
Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 179 Registered: Sep-05 | 1800@1 ohm but i doubt it does the full 1800. it is a power acoustik. lol. |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 848 Registered: Dec-06 | well for one sub 1800 is a little much for most of the subs u mentioned. the sd2.5 is only 500. the ssd is only 800. the q is only 1000 and like i said 1800 might be pushsing it. can u build or get another box for 2 subs? if so ide get 2 sd2.5's or 2 ssd's |
Silver Member Username: HgihkcinLincoln, NE Post Number: 135 Registered: Sep-05 | Get the fi BL and get the cooling option its 40 bucks more than the q but you would for sure be ok runing the suposed 1800 watts |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1580 Registered: Jul-06 | SX |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 849 Registered: Dec-06 | ^^^^^the bl with cooling options x2 |
Silver Member Username: HgihkcinLincoln, NE Post Number: 136 Registered: Sep-05 | yaya somebody agreed with me... i think this is my first post i ever helped someone |
Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 180 Registered: Sep-05 | well snarl the box i have planned is the largest i can go unless i get flared ports but it will only give me another .4 cu. ft. or so. its going as the center console in a 2006 gmc sierra. so the max dimensions are 34w x 13.75h X 14d. nick have you heard a bl in this small of a box? i have not heard them but most people say they are pretty loud. |
Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 181 Registered: Sep-05 | and Snarl i dont think my amp is running the full 1800. does anybody know how to get an amp bench tested? or how i can do it myself? |
Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 182 Registered: Sep-05 | M.S. does the sx get loud? have you heard one? i heard they have great sq. |
Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 183 Registered: Sep-05 | i can get 2.8 cu.ft. if i go sealed. would two sealed subs be better? maybe two type r's. but i do still want them to get loud. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1591 Registered: Jul-06 | " does the sx get loud? have you heard one? i heard they have great sq " Umm, you've heard wrong then. They are an SQL sub leaning toward SPL. I have not personally heard one, but I have seen them used in several installs, and the numbers they put up were very impressive...... |
Silver Member Username: MgbcsLincoln, Nebraska Post Number: 927 Registered: Dec-06 | The SX sounds pretty good and gets plently loud. I have heard one in the back of a Grand Prix with like 900 watts. I can only imagine one in a truck with 1800 (or anywhere near that). |
