If I run this at 2 ohms how many amps would that pull constantly at about 3/4 volume? I was just wondering if 2 ohm and 1 ohm operation will change how many amps it uses.
"I was just wondering if 2 ohm and 1 ohm operation will change how many amps it uses." yes, using will 1ohm will greatly increase the current draw over 2ohm
Hey Nate, where can I get one of those 100% efficient Memphis 4kws? lol. The numbers matt posted are a more accurate guess.
" yes, using will 1ohm will greatly increase the current draw over 2ohm "
Usually true. Most amplifiers affiance drops substantially as the impedance is lowered. When a manufacturer gives you an efficiency rating, it is usually a 4 ohm rating.
what happens if u have say a 225 alt amp and a few yellow top batteries, will you be ok if u run it at 1 ohm and have a few capacitors, will it run ok with this amp?
I was thinking a 350 amp alternator, a yellow top or Kinetik battery (for the back, stock up front or redtop) and a 4 farad capacitor (in that order). Sounds like a decent start to a charging system
350 Amp alt? where you getting that??? Its not going to be a direct bolt on... you need to find somhere to make custom brackets for a second alternator and thats ussualy around 2Gz from what i hear... i still cant even find anywhere to get it done for myself..
