JL 15W6 setup?
Username: Philly306
i have two jl audio 15w6, and i want to get the most out of them. One or two amps? and what wiring? As you can tell i am new.
Username: Oleg
Santa Monica, CA USA
Post Number: 830
budget?
Username: Philly306
Post Number: 10
ive saved alot of money for a system and i got the subs free so.. id say alot
Username: Oleg
Post Number: 834
To match those perfectly is JL 1000/1 at over $600 on eBay. Also, arc audio FD1200.1, JBL BPX1100.1, new sundown amp (heard you can pre-order for $225), and RF T1000B is another good one. Also consider orion HCCA-D2400.
Username: Sqhoe
Huntington, IN USA
Post Number: 8
Those subs stink. Just give them to me. Just kidding. Actually, I had one of those subs in a Monte Carlo with 300rms and I have to say, I miss that thing. Great subs imo.
Username: Dlavante
Tigard, Or USA
Post Number: 68
ed nine.1 would be awesome with those subs
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12131
vc configs on the subs??
Username: Philly306
Post Number: 17
umm i dont have a clue what that means
Username: Oleg
Post Number: 917
Phil, are you sure the subs are 15w6? I've never heard of a 15" JL sub. Maybe it's the 13W6?
Chauncey, I think w6 is dual 4ohm.
Username: Philly306
Post Number: 18
yea im sure they are 15 and they are 6 ohm
the 15w6 is discontinued
http://mobile.jlaudio.com/products_subs_pages.php?page_id=15
go to this^^ scroll down and find 15w6, it tells you everything
Username: Killswitchjd
Post Number: 414
dual 6 ohm
Username: Oleg
Post Number: 922
So you'll need something that does about 800W @ 3ohm.
Try
1.ALPINE PDX-1.1000
2.JBL GTO1201.1
3.Kicker ZX1500.1
Username: Philly306
Post Number: 19
thanks thats what i needed
