New member Username: Biga524
Post Number: 6 Registered: Apr-07
Posted on I just purchased Onkyo TX-SR804 and the Polk RTi10 Is bi-wiring good? I know how but can you do that with this reciever? or is it just a amp? thx |
Bronze Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 41 Registered: Feb-07
Posted on You bi-wire from a receiver as well. Not really sure what the point is... I tried it before and didn't notice any difference whatsoever. Bi-amping is a different story altogether. |
Gold Member Username: Kano
BC
Post Number: 1177 Registered: Oct-04
Posted on Yes bi-wire, I noticed better low end finesse with my Polk Rti8s |
Post Number: 7 Registered: Apr-07
Posted on Kano..did you bi wire just useing a reciever or seperate amp? thx |
BC
Post Number: 1179 Registered: Oct-04
Posted on Both, I initially bi-wired to the receiver. I connect with a banana into the receiver and bare wire into the speakers. I later added a 200W x 2 power amp and noticed more bass, but the transitional bass improvement was the same between both receiver and amp. |
