HOOKING UP A SURROUND SOUND SYSTEM, CABLE BOX TO A LCD TV
Username: Astisma
Midwest City, OK USA
We got a new flat screen and surround system. We have never had one of these before. When I turn on the surround sound system, we get no sound unless we watch a DVD. I need help to hook this up so I can use the surround sound while watching TV. Thanks a lot.}
Username: Project6
Post Number: 13743
Did you read the manual?
Username: Huron
Post Number: 35
thats the funniest thing I new you were going to say that, didnt we just go threw this
Username: Huron
Post Number: 36
I wonder if anything needs to be said exept, go to, connected tv to yamaha receiver
Username: Astisma
yes i read the manual. but i cant get the surround sound to work when I watch the TV. The surround sound just works when I watch a DVD.
Username: Project6
Post Number: 13745
Look at the back of your TV...check for connectors that are marked "AUDIO OUT".
Connect this to your receiver that is marked "AUDIO IN".
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 349
Do you have a cable box? If yes hook up the cable box using digital coaxil or Red and white RCA cables to your receivers video 1 input. If no use Bernys' advice.
Username: Astisma
Thank you so much Casey. That was layman enough for me to understand and it worked!
Username: John_s
Columbus, Ohio US
Post Number: 1509
Good one there Casey. Sometimes you have to read between the lines, given the info you have at the question.
