Bronze Member Username: Xfacta82Post Number: 40 Registered: Mar-07 | I have a pair of CDT HD-62 components up front and CDT Cl-69x in the back. I was going to get this amp. http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5465 Is it good for what I have? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1557 Registered: Jul-06 | That's a good amp and it would work, but those speakers can take about double that amount of power. I would look for at least a 150 watt per channel amp. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4413 Registered: Dec-05 | i totally agree^^^. Maybe you should consider something like massive audio 800.4 |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1561 Registered: Jul-06 | ^^^^^ X2 Massive 800.4 would be a great match. Talk to Kevin from low-hz he is a dealer for Massive..... |
Bronze Member Username: Xfacta82Post Number: 41 Registered: Mar-07 | How much are these amps....I was looking to stay around 250 or so. How can I reach Kevin |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1566 Registered: Jul-06 | Don't know the price, you'd have to ask Kevin. His email is: lowhz01@yahoo.com |
Bronze Member Username: Xfacta82Post Number: 42 Registered: Mar-07 | So is that alpine not good at all. I dont want to go much higher in price than that. Do i really need that extra power to get the best sound out of my speakers? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1576 Registered: Jul-06 | Not to sound like an as$, but why buy such a nice set of top-of-the-line components when your not gonna power them properly? It's like putting a Honda motor in a Ferrari...... |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4425 Registered: Dec-05 | ^^^^^x2 ...."I was looking to stay around 250 or so. How can I reach Kevin". I'm totally sure the price is around 250$ and you can PM him by here or his email up there. Alpine is not bad, problem is the power you need to obtain the best from those components |
