im having a major problems with putting the keys in i need dishnet and bell ones that work please and can someone tell me how to put them right too thanks
1. Hit the "Menu" button. 2. Then scroll down to "Installation." Hit the "OK" button. 3. Now scroll down to "Code" and hit the "OK" button. 4. Next scroll down to "Nagra" and hit the "OK" button. 5. On the next screen, hit the left arrow to get to the key window for the provider you need. Make sure you go to the second one of that provider. If you don't see 5 lines of code (for Dish Net,) then you need to hit the left arrow again. Dish Provider ID is "Dish Net 010100," and Bev Provider ID is "Bev 090100. 6. Now skip the first line of code. Do not alter this line. (For Dish Net Only) 7. On the second line, it should start with 08. Using the right arrow, move to the next set of digits. You will always want to leave the first 2 numbers there. They identify the line. 8. Enter the first half of Key 86 (Key 00) into line 08. 9. Next enter the second half of Key 86 (Key 00) into line 09. 10. Then enter the first half of Key 96 (Key 01) into line 88. 11. Then enter the second half of Key 96 (Key 01) into line 89. 12. Remember, DO NOT ALTER THE FIRST 2 DIGITS OF ANY OF THESE LINES. Start with the second set on each line. 13. Now hit the "Exit" button. 14. Highlight "Yes" and hit OK. 15. Exit out of the menu, and change the channel. 16. Watch TV. Buttons may differ for some recs. Here are the buttons for the letters. A = F1 (Red button) B = F2 (Green button) C = F3 (Yellow button) D = F4 (Blue button) E = Goback (bottom corner of the number pad) Rewind on the 7000PVR F = Color / Slow on the 7000PVR Delete = Guide
