Bronze Member Username: Newkid77Columbus, Ohio Post Number: 45 Registered: Mar-07 | I am going to install a 2400 watt amplifier with two subs. Right now i have a stock alternator of 105 Amps in a 1997 Grand Prix 3.8L . Will i need a HO alternator of 160 or 200 or even another battery? This is the amp: http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16367 Alternators: http://www.motorcityreman.com/high-amp-alternators-pontiac-grand-prix.html |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 508 Registered: Nov-05 | that amp is only a 1200 watt amp and u will only see about 900-1000 of it anyway. What subs do you have? Buying a HO Alt is a good idea no matter what your running. If you have the money it's a great idea. Then upgrading the amp is the next step. Give us a budget because that amp is not very high quality, more of a budget amp. Let us know what subs you will be running though... We can help you! |
Bronze Member Username: Newkid77Columbus, Ohio Post Number: 47 Registered: Mar-07 | My budget is about $700-$800. That budget includes HO alternator,subs, amp, box, and a wiring kit. I was looking to get 2 pioneer subs, which i can get for $70 each. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17388 I found a 160 amp alternator for $200. And i can get the Hifonics amp for $235. Box and wiring kit each $50. But if you dont think that config isn't good i can change it up because i havent ordered anything yet. Thanks. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2059 Registered: Jul-06 | That amp only does about 900 watts...... you probably won't need to upgrade the electrical system. |
Silver Member Username: Dakangofkrunk16PLANET EARTH, FLA Post Number: 966 Registered: Mar-07 | dont get cheap subs to save money go with a FI SSD get the 18 and that amp and have logan or cannan build u a box no need for HO alt |
Bronze Member Username: Newkid77Columbus, Ohio Post Number: 49 Registered: Mar-07 | what is a FI SSD ? I searched it on google and nothing came up. |
Silver Member Username: Dakangofkrunk16PLANET EARTH, FLA Post Number: 971 Registered: Mar-07 | Ficaraudio.com prolly the best subs out there for the money Scott atwell one of the mans behind RE left Re to form this company |
Silver Member Username: KillswitchjdPost Number: 463 Registered: Apr-06 | you sound like you have no idea about car audio. but I say grab that alternator if you have the money. The amp will put out more power if it has some headroom... 14.7 maybe? |
Silver Member Username: Dakangofkrunk16PLANET EARTH, FLA Post Number: 978 Registered: Mar-07 | yea not knowin about Fi defidently a noob when i came here i didnt no about FI |
Bronze Member Username: Newkid77Columbus, Ohio Post Number: 51 Registered: Mar-07 | yea i am a noob but i'm trying to learn and get experience. Thanks for the info. |
