Post Number: 402 Registered: Feb-07 Posted on Thursday, April 12, 2007 - 07:51 pm:
-------------------------------------------------------------------------------- i was helping friend i tried to flash pansat2700 i fallowed the insruction all i get is night rider . when i flashed with the new boot i only see night riders. and no it stuck in night riderswhat the hell is wrong with this
Post Number: 404 Registered: Feb-07 Posted on Saturday, April 14, 2007 - 12:08 am:
-------------------------------------------------------------------------------- i flashed with the latewst bin . i was not sure if the process was complete beforer i unplague the electric wire. i think the process was final cuz i saw the channel numbrers. . but when i tried to connect it to the tv . i only saw little light like it's gonna reboot but then the light went off. now the reciever is dead. i tried to revive it using viewsat lite the old version since it has same software as platinum . nothing is happening . i changed the fuse , i saw once some flashing and then nothing . i changed again the fuse nothing . is there any other way of reviving my dead reciever.? jtag or whatever before i send it to be repaired. thanx fellas.
I loaded the latest bin on my platinum after a couple hours the picture froze and "inst" showed on the display and picture froze, once turned off it was dead. i.e. won't power on. No lights and no sign of life.
Things that I have tried: loading factory bin. - Same result won't power on and so will not load.
Have not tried cloning with another Viewsat [this is the only one I have]
Any ideas on how to revive this unit? Unit is approx. (2) years new.
Thanks.
poimoe View Public Profile Send a private message to poimoe Find all posts by poimoe Add poimoe to Your Buddy List
#2 2 Days Ago 10stewart Junior Member Join Date: May 2006 Posts: 7
Reporting same problem....I know the board is passing energy, it makes the (dat) sound when I turn it on connected to TV, display is messed up or no coming on at all. I checked the inside fuse and is ok. Tried cloning with my other VS2000 patched and in good condition but it doesnt boot.
venjra View Public Profile Send a private message to venjra Find all posts by venjra Add venjra to Your Buddy List
#5 2 Days Ago DAB Junior Member Join Date: Feb 2006 Posts: 19
I wonder if this new bin it is OK.. My platinum has not loaded the new bin is acting like has no recognized the communication port. We need advice and urgent.. Note: we could seriously harm our receivers.
DAB View Public Profile Send a private message to DAB Find all posts by DAB Add DAB to Your Buddy List
#6 2 Days Ago jodi losee Member Join Date: Jul 2006 Posts: 77
Quote: Originally Posted by venjra Reporting same problem....I know the board is passing energy, it makes the (dat) sound when I turn it on connected to TV, display is messed up or no coming on at all. I checked the inside fuse and is ok. Tried cloning with my other VS2000 patched and in good condition but it doesnt boot.
i had the same problem guys and no matter what i did nothing i had to take it in to the repair shop the other day still waiting to hear back on it but it is like it is in sleep mode
jodi losee View Public Profile Send a private message to jodi losee Find all posts by jodi losee Add jodi losee to Your Buddy List
#7 2 Days Ago boardpro11 Junior Member Join Date: Jun 2006 Posts: 3
can somebody explain in detail how to clone the viewsat xtreme reciever i also have the same issue as you guys with having no power once i installed the latest fix.Thank you i am desperate to watch the playoffs.
boardpro11 View Public Profile Send a private message to boardpro11 Find all posts by boardpro11 Add boardpro11 to Your Buddy List
#8 2 Days Ago hogowner Senior Member Join Date: Jan 2006 Location: Hangin with JENNA, making a Spice Clip Posts: 6,343
Quote: Originally Posted by boardpro11 can somebody explain in detail how to clone the viewsat xtreme reciever i also have the same issue as you guys with having no power once i installed the latest fix.Thank you i am desperate to watch the playoffs.
all you have to do is click on the search tab on top....alot of threads on what you need __________________ Viewsat Platinum Viewsat Extreme Viewsat Ultra SonicView 1000 SonicView 4000 SlingBox 2 Dishes with 4 Legacys 82,91,110,119
________________ If you do your reading and can't find an answer for your problem, you can PM me
hogowner View Public Profile Send a private message to hogowner Find all posts by hogowner Add hogowner to Your Buddy List
#9 2 Days Ago fleafta Junior Member Join Date: Feb 2007 Posts: 16
i loaded the new file that was posted wed and right after i powered my reciever off when i saw the 4 0000 i went to plug it up and nothing happened man sounds like we all have the same problems man we need help huh
fleafta View Public Profile Send a private message to fleafta Find all posts by fleafta Add fleafta to Your Buddy List
#10 2 Days Ago golf Junior Member Join Date: Oct 2006 Posts: 7
From what I've observed on this site and others is that this is a common problem with clones. If it is not a clone, you can send it to viewsat for repair.
Is Viewsat doing what Pansat did a little over a year ago??? Viewsat has to make this good. All the loyal Viewsat customers are left in the dark??? Everything was fine until this latest bin file!!!!!!!!!!!!! Two Viewsat Lites bought from an authorized Dealer are both now DEAD!!!!!!!!!!!!!!! Loaded the Latest Viewsat Bin of 04/11, worked for a couple of hours then display said INST, picture froze, and now all BLACK.
-------------------------------------------------------------------------------- Last edited by sam_numbers : 1 Day Ago at 11:35 AM.
sam_numbers View Public Profile Send a private message to sam_numbers Find all posts by sam_numbers Add sam_numbers to Your Buddy List
#23 1 Day Ago rodothensum Junior Member Join Date: Aug 2006 Posts: 4
There is absolutely a problem here, I have at least 15 units (Not a single Clone. although I'm wishing they were, at least you can fix a clone yourself!)under my belt all platinums..4 machines are junk now after the 07 code was put in. Sounds like a great way to get customers to
A) Pay a service fee for repair or B) Buy the new latest and greatest reciever. C) A undertested Bin released.
I'll say this Viewsat has been incredible with quick bins and leading quality. But..This board will show just how many others were hit by this bin and I for one will not buy another unit from Viewsat..Unless I know there is a way to Completely Zero out the Flash chip and start from scratch or I have a promise from Mister Viewsat that He will foot the bill for any repair that is needed for the units. It's not just the platinums its the extreme's as well. That's my rant. Think what you want.
rodothensum View Public Profile Send a private message to rodothensum Find all posts by rodothensum Add rodothensum to Your Buddy List
#24 1 Day Ago JackSparrow Senior Member Join Date: Jul 2006 Location: The Black Pearl Posts: 309
Quote: Originally Posted by rodothensum There is absolutely a problem here, I have at least 15 units (Not a single Clone. although I'm wishing they were, at least you can fix a clone yourself!)under my belt all platinums..4 machines are junk now after the 07 code was put in. Sounds like a great way to get customers to
Not to be mean or anything, but this is a testing hobby, if u are worried about loading new bins, FINE no 1 is forcing u, If u hate viewsat cus yur plat died, FINE don't purchase anymore viewsats, I've heard a lot of people criticizing mr. viewsat, Mr. Viewsat this and that, well Apparently most people don't understand that it isn't as easy as u guys think it is, People make mistakes, If u don't like the lil glitches u grt once a while FINE, trash yur Viewsat and switch to Dik Network subscription... AND Mr. Viewsat is releasing bins early because that is general for all business, U wanna release yur product first, That's why the man we call Mr. Viewsat is Mr. Viewsat, So to the people pissed off at Mr. Viewsat, you have no 1 or nothing to blame but yurself and your stupidity for buying this unit in the first place if you didn't trust it, Mr. viewsat is working hard and u can either support Viewsat and read more and do something Positive or u can throw away yur STB, Yaa every1 wants everything Perfect: A Perfect Bin ASAP at instant, that isn't bugged, well I want a million dollars in my hand at this instant, it doesn't mean anything, Deal with what you have! In other words if the bin is bugged oh well deal with it for a while, I trust the VS team's support and I have faith that they will fix it because I trust the Viewsat Brand and thats why I bought 4 Platinums! __________________ Charlie stole my Rum
JackSparrow View Public Profile Send a private message to JackSparrow Find all posts by JackSparrow Add JackSparrow to Your Buddy List
#25 1 Day Ago SideLineMgr Senior Member Join Date: Jan 2006 Location: U.S.A. Posts: 112
this reminds me of the 0304 killer bin that surfaced in march. box works fine for a while, buzz, inst, then once you turn it off you get no lights on the front of your receiver.
from what i know this may be due to user error (loading a plat file on an xtreem or vice versa then reloading the right file, or not waiting an extra few minutes after the box finishes loading the file). or it may be something in the file, clone kill code etc..
the tsop chip is corrupt and will not allow the proper booting of the machine.
to fix your box you have 3 options.
1. send it back to a viewsat repair center --$50-100 2. find an independent electronics repair shop to remove the bad chip (tsop) and reprogram it --$40. 3. follow the junkyard fix thread and hope they come up with something soon--free.
there are no other options these dead boxes need their hardware fixed, at present time there is no software fix.
markymark2 View Public Profile Send a private message to markymark2 Find all posts by markymark2 Add markymark2 to Your Buddy List
#27 1 Day Ago rodothensum Junior Member Join Date: Aug 2006 Posts: 4
Well Mr Jack Sparrow, I love the Viewsat Box..as I mentioned. And have supported the box for a long time..But..Just you wait and see how many receiver's go down in the next while..obviously your box is fine. for now. I am not known as a negative person..but..the proof is in the pudding. Just watch and see what happens to all of our viewsats in the future. Like I said if this is going to be a problem issue..viewsat instead of charging for repairs should sell a device to manually recode the chip onboard via the serial port.. or something like that. I have always supported viewsat..but the hardware needs a work around.
#28 1 Day Ago special_ed Junior Member Join Date: Jun 2006 Posts: 4
Is is saft to send back these viewsat receivers with altered code on them? This is proabably a naive question but should we? If so , where do you get the forms?
special_ed View Public Profile Send a private message to special_ed Find all posts by special_ed Add special_ed to Your Buddy List
#29 1 Day Ago JackSparrow Senior Member Join Date: Jul 2006 Location: The Black Pearl Posts: 309
Quote: Originally Posted by rodothensum Well Mr Jack Sparrow, I love the Viewsat Box..as I mentioned. And have supported the box for a long time..But..Just you wait and see how many receiver's go down in the next while..obviously your box is fine. for now. I am not known as a negative person..but..the proof is in the pudding. Just watch and see what happens to all of our viewsats in the future. Like I said if this is going to be a problem issue..viewsat instead of charging for repairs should sell a device to manually recode the chip onboard via the serial port.. or something like that. I have always supported viewsat..but the hardware needs a work around.
Yaa I understand, my response earlier in this thread wasn't for u but it was for others throughout this site who are angry at Viewsat, and really there are a lot of protective procedures that can be utilized for protecting yur receivers from death, I loaded 070407 an earlier file which rolled fine, I am a kinda of guy who doesn't load anything until I get a black screen, in other words, i won't try to fix it if aint broken, the 070407 bin worked fine, it was posted on the front page, What i did was load a factory file like 2051 or 0271, and THEN load the bin. The last bin I loaded was back in Febuary. Receiver worked fine not only 1 but all 4 of mine. and i READ the feedback that lies in these wonderful and helpful forums, and if i read that atleast 1 receiver died from this bin then i wudn't load it, i don't care if my receiver gives me a black screen for a couple of days, Heck i will just turn A/R off and load opkeys, up to a point where i see a solid bin release just like the 070407. Ya the hardware needs work, but i am pretty sure sooner or later, viewsat will figure it out because i trust Viewsat and their support, even if my plat dies i am happy that i had 4 plats running for 1+ years and that made me gain a lot of trust and support for the VS team and Mr. Viewsat __________________ Charlie stole my Rum
#30 1 Day Ago 70 Buick Senior Member Join Date: Jun 2006 Location: Montreal Posts: 437
It is not a biggy, I have lost 3 plats in the last few months , & the next guy who says it was user error should be shot !!!, I have loaded 1000's of machines over the years & have been a very loyal VS user , I am not pissed at VS, They have just lost my business, all dead ones have been & will be replaced by SV's , No use screaming about it , the only way to get VS to stop the killer bins is to buy another box , end of story , That or sub, It is just bad business thats all !!!
So after you killed another box,you decieded to look for a remedy, big deal.Your c/p's just prove your not the only "idiot" out there,but your still a looser. "IDIOT".
so when poeple have prob with fta they are idiots. right? you know my dickkkkkkk are you used to it now. i dont fuckk boy but i get you im gonna stick it in your assssssss and pull it and give it to you to suck it bitchhhhhhhhhhhhhhhhhh. go look for job. stop being a faggggggggggggg , get a life
