Silver Member Username: Trey4sportsPost Number: 955 Registered: Sep-06 | im meetin my dad to pickup my range rover and i would like to do upgrade big3 wiring right there but i would like to have the lengths already cut before then. i know ever vehicle is diffrent but what do you guys think is a safe set of lengths?? i was thinkin 4 ft run, 3 ft run, and another 3 ft run?? |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 1854 Registered: Jul-06 | MEASURE. |
Silver Member Username: Trey4sportsPost Number: 956 Registered: Sep-06 | "im meetin my dad to pickup my range rover" dont have my vehicle with me ^^^.....what is a good base number for the measurements as i havent bought the run of 0 GA and dont want to go over just lookin to get fairly close...waht are we talkin here probably 10 ft or so ?? |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12029 Registered: Oct-05 | just take the roll with you. how long does it take to cut it and crimp the terminals? |
Gold Member Username: CtmikeCt. Post Number: 3932 Registered: Feb-06 | i'd just take a measuring tape and measure/cut there. 0 gauge is expensive and you don't want to make any mistakes. plus, even if you cut it at 10ft. now you'll more than likely have to cut it again later, so just get there and make the cuts' once imo. |
Silver Member Username: Trey4sportsPost Number: 957 Registered: Sep-06 | yeah that sounds good, i just dont want to buy to much BECAUSE im going to buy it from knukonceptz so if i get 10 ft and i only need five then i pretty much wasted the other 5ft...anyway i guess ill just measure first then order...ughhh i hate waiting |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12030 Registered: Oct-05 | just buy a roll trey. you can never have too much 0 guage. |
Silver Member Username: Trey4sportsPost Number: 958 Registered: Sep-06 | ehh... when you work for 6.50 an hr and you have to balance a high GPA you can DEF buy too much 0 ga lol |
Bronze Member Username: RidinspinnasCayuga, Ontario Canada Post Number: 82 Registered: May-06 | how much a roll of 0 gauge? |
Gold Member Username: CtmikeCt. Post Number: 3933 Registered: Feb-06 | depends where you buy it and how much. think it's cheapest at knukonceptz. http://www.knukonceptz.com/ |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 5555 Registered: Jun-06 | Every time I order wire, screws, adhesive, carpet, whatever, I always order double what I need. It sux when you're in the middle of a project and you run out of something. Seeing as you could be doing this for years, it just makes sense to buy it at todays prices, if you can. JMO. |
Gold Member Username: CtmikeCt. Post Number: 3936 Registered: Feb-06 | good point^^. especially since cost of wiring just went up. that's why i'm buying 50, maybe 100ft., of 0 gauge now. |
Silver Member Username: Trey4sportsPost Number: 959 Registered: Sep-06 | yeah thats cool, i understand where you guys are coming from. |
Silver Member Username: Skibum12189Cleveland Post Number: 453 Registered: Mar-06 | """" ehh... when you work for 6.50 an hr and you have to balance a high GPA you can DEF buy too much 0 ga lol """" x1000000000000000 ahaha how nice was the 5.15 to 6.85 minimum wage increase just bought mine for goin distros to amps, but knukonceptz is only like 20 minutes from my hosue but still i know where youre comin from |
Silver Member Username: Trey4sportsPost Number: 970 Registered: Sep-06 | lol, damn ur lucky. the F'n retards are my local shop wanted like 4.90 for kicker hyperflex...dam i kno copper is expensive and all but thats redic |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 339 Registered: Jan-07 | ^ in here thy wanted to charge my $200 for a generic amp kit 1/0. so i bought knukonceptz |
