New member Username: FrmgrlAlberta Canada Post Number: 4 Registered: Apr-07 | Loaded the new file into my Sonicview 1000, autoroll works fine for Bev but not for DN. Can anyone help me please? What should I do? |
Gold Member Username: TapemanNew York, NY Post Number: 1005 Registered: Oct-06 | I'm so sorry about the bad service U R getting Put the key by hands ![]() ![]() ![]() https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1113488#POST1113488 |
New member Username: FrmgrlAlberta Canada Post Number: 5 Registered: Apr-07 | I put the DN keys in manually still on working. made sure had correct keys. I even checked to make sure auto roll was turned off too. DN still not working. What now? |
New member Username: FrmgrlAlberta Canada Post Number: 6 Registered: Apr-07 | I meant DN not working. instead of on supposed to be not. Thanks! |
Silver Member Username: HardrockstrikerPost Number: 748 Registered: Apr-06 | You must have an error in your key entries somewhere. Double-check. |
Gold Member Username: TapemanNew York, NY Post Number: 1007 Registered: Oct-06 | Try to reset from back switch |
New member Username: FrmgrlAlberta Canada Post Number: 7 Registered: Apr-07 | Just double checked. Still nothing. |
Gold Member Username: TapemanNew York, NY Post Number: 1009 Registered: Oct-06 | Turn off switch and back on again. it must of frose |
New member Username: FrmgrlAlberta Canada Post Number: 10 Registered: Apr-07 | Just did the switch thing still nothing. The guide is working alright though. |
Gold Member Username: TapemanNew York, NY Post Number: 1012 Registered: Oct-06 | Something must of Frose Rose Are You Using These Keys? Dish Network (Last Update: 2007/04/11 7:30 PM EST) 00: B8 46 82 2D 29 B6 25 87 8C B1 63 15 24 65 0D 8A 01: 53 B1 5A D5 D0 FD 53 8C 6F 19 5F DE BF 78 80 8E (Active) |
Gold Member Username: NydasPost Number: 2330 Registered: Jun-06 | Rose: Soniview autoroll is workig fine. Suggestion: Turn auto roll off. Put any false keys in manually - both Key 00 and Key 01 for DN. Turn auto roll on. Switch off receiver. Wait for 1 full minute. Turn receiver on and wait for keys to roll in. |
Bronze Member Username: FrmgrlAlberta Canada Post Number: 11 Registered: Apr-07 | Sorry didn't work either. |
Gold Member Username: NydasPost Number: 2341 Registered: Jun-06 | Rose: You must have a bad BIN upload. You should consider reloading the factory BIN and then the latest. |
Bronze Member Username: FrmgrlAlberta Canada Post Number: 12 Registered: Apr-07 | Where can I get a factory bin and a good current Bin? Thanks ![]() |
Silver Member Username: RunnerguyPluto Post Number: 167 Registered: Sep-06 | Try reading a little Rose |
Gold Member Username: NydasPost Number: 2345 Registered: Jun-06 | Rose: The sites: |
Silver Member Username: HardrockstrikerPost Number: 752 Registered: Apr-06 | Nalin, if what she says from her first line in this thread is true then she must have a working bin (because she gets Bev with autoroll). I'm just wondering if she ever had DN working in the past, or, if she tinkered with her receiver settings? But you're correct, she does need to read a bit in order for her to troubleshoot. |
Bronze Member Username: FrmgrlAlberta Canada Post Number: 13 Registered: Apr-07 | DN worked before I loaded Bin 257. |
Silver Member Username: HardrockstrikerPost Number: 753 Registered: Apr-06 | Okay, so if you're getting Bev fine, at this moment then it has to be your receiver set up or keys. I would leave DN autoroll on because the autoroll should work with your bin. are your lnb types set properly for your DN sats? do you have the lnbs mapped to the correct switch ports? |
Gold Member Username: LklivesPost Number: 8748 Registered: Jan-06 | Rose New member Username: Frmgrl Alberta Canada Post Number: 4 Registered: Apr-07 Posted on Thursday, April 12, 2007 - 10:37 am: -------------------------------------------------------------------------------- Loaded the new file into my Sonicview 1000, autoroll works fine for Bev Nalin Nyda Gold Member Username: Nydas Post Number: 2341 Registered: Jun-06 Posted on Thursday, April 12, 2007 - 02:50 pm: -------------------------------------------------------------------------------- Rose: You must have a bad BIN upload nalin, there U go again, talking out your azz!.. |
Gold Member Username: NydasPost Number: 2348 Registered: Jun-06 | LK: Buzz off: We are trying to help Rose. If you have nothing postive to say - GET OUT!!! |
Bronze Member Username: FrmgrlAlberta Canada Post Number: 14 Registered: Apr-07 | Thanks everyone for your help. Problem solved. My settings were wrong. Thanks again! ![]() |
