New member Username: AngelodileonardoElmer, N.j. Usa Post Number: 6 Registered: Apr-07 | how do you connect 3 equalizer to the reciever to use the speakers there is only one main input and output im using a yamaha dsp-a1 or should i use both receivers rx-v1 and the dsp-a1 i can use the equalizer to the mains but what about the rear output or do i need to get a converter for input and output to run these speakers also im going use the v-10 center speaker from bose i think thats the number v-10 but anyway need some help thank you |
Platinum Member Username: Project6Post Number: 13748 Registered: Dec-03 | Check here https://www.ecoustics.com/electronics/forum/home-audio/1052.html |
