Amp Q
Username: Kaprese
Walstonburg, NC USA
Post Number: 74
I have a kenwood amp and it's a 2-channel it's around 300w a channel but every time I turn my HU on and turn the volume to zero the subs be poppin and moving on there own an when I turn the volume up it goes away and when I turn it back to 0 the sub starts up again I have my positive and negative speaker wire in bridge mode could this be the problem and I am not using bass boost what could the problem be I have good ground and power
Username: Nd4spd18
Southeast PA
Post Number: 1523
My first guess would be that the gain is too high. Check your gain with a DMM and set it properly.
Username: Mash4kash
Lafayette, LA
Post Number: 252
could be a bad ground too, happened to me. Another was an internal fuse in my HU
Username: Kaprese
Walstonburg, NC USA
Post Number: 75
Alright because at first I thought it was the amp until my brother put my HU and Amp in his car and it did the samething but the only difference was he had a L7 15 that someone gave him so I will check into it today
