I did all kinds of scans with my Pansat 2700A, but I can't seem to get any HBO channels except HBO Comedy. Can someone tell me how to get this? And if I have to install a guide, can you give me the link for it. Also it is very important for me to have International channels in it as well. Thanks in Advance, I will really appreciate this.
Same problem here...I just installed my Pansat this past weekend - I had subscribed in the past, so I already had a dish with 2 LNBs. I just connected my Pansat directly to the dish and I was able to get most channels including adult, but I cannot get HBO and some other "common" channels like CNN, A&E,...
As far as international channels, you may need a second dish pointed in another direction to receive those (depending on where you are). I know I do.
There is a large bush in the way that grew since the dish was originally installed, but I can still get over 100 channels. Is it possible that the bush is "blocking" HBO and the others?
Sanjay Patel u are aiming to 110 i guess cuz you have no cnn no HBO'S .THE HBO YOU GOT IS IN 110 AND NOT 119 . TRY TO GET ECHO7 SIGNAL IF U WANT TO WATCH HBO.
Hi Cartier1, I re-checked the connections from the dish and was able to fix the problem - I now get some of the HBO channels as well as CNN and Sirius stations. Thanks for the input.
Unfortunately, I still don't get all of the 119 channels. I have a Pansat 3500SD that I purchased pre-programmed from someone so I have no idea if the keys are outdated or not. Do you think it is possible that the keys could be the problem (before I try messing with the box, I want to make sure I am not wasting my time trying to do something I don't know anything about)?
hi every body i have a problem with abc them networks .what happens to all of the networks i am only getting one of each the lower sets some days they dont come in .i use to get about 4 abc now i can only get one .do they take them out or channel listing will bring them back or tell me where to go so i can read about them.pleeese help.
