Pansat 3500SD display s b-70
Username: Frobi
Guelph, Ontario Canada
Post Number: 37
My pansat 3500sd displays b-70 and can can not turn it off nor on except from main switch at rear. How can I fix it. Also what new bin file and loader do I need to get DN. Will appreciate your help.
Username: Thunder_lightning
Post Number: 219
sheel....you got niterider...reload your last bin will solve the problem...than load this new bin...
bin... (3500) x05bl 319 (Apr 11 07]..this is not a clone bin..
loader...loader V3.4
http://www.dssrookie.com/forums/b-font-color-cd2626-3500-files-font-b/
Username: Hardrockstriker
Post Number: 742
You will also need to upgrade your boot file to b-80 to make the 319 bin work. You can use the same loader to upgrade your boot file.
Post Number: 223
Thanks Jason Borne..just forgot about the b-80 thing...
Username: Frobi
Post Number: 39
I did load the boot file b-80 but still thew display does not change. still it shows b-70. i even tried 35005_070311_B8-_v03_api, but no change. Any suggestions? Thanks in advance
Post Number: 745
Do a factory reset on the receiver (thru the menu). Then load the factory bin for your Pansat (you can get this bin at Pansat-usa site). That puts you back to square one.
Now, load the b-80 boot file. After loading that file DO NOT turn your receiver off. Load your new 319 bin.
You will have to reconfigure your receiver (antenna settings and scans) to get your tv back.
