Quatnum Audio QCA4000D
Username: Mash4kash
Lafayette, LA
Post Number: 115
Is Quatnum Audio Cozmik series amps any good?they're class AB The QA4000D says 4000w rms in 1 ohm @ 14.4v and 2000w rms in 2 ohm @ 14.4v here's the link http://www.quantumaudio.net/cozmik-amp.html
Username: Nd4spd18
Southeast PA
Post Number: 1273
No, and didnt you post this in the sub section? I posted in that thread.
Username: Mash4kash
Lafayette, LA
Post Number: 118
o nah I didn't post in the sub section but i did check out the thread so I'm gonna save my money for better quality then
Username: Dakangofkrunk16
Earth
Post Number: 383
na that was me that posted it in the subwoofer section
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4365
forget about that amp.
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 532
any of u actually used one of their amps? i had the 3kw and it was powerful but drained a lot of power
Username: Nd4spd18
Southeast PA
Post Number: 1446
With two 60 amp fuses that thing ain't gonna draw a lot of power, lol.
We've been over this already:
https://www.ecoustics.com/electronics/forum/car-audio/343224.html
TWO EGG, FL USA
Post Number: 534
like i said have u used one and yes it does draw alot of power we got a 235 amp alt and a batcap 400 i can tell if it draws alot or not ive owned a ss-6500 a orion 2500d and other high power amps and this one drew more power than the 2500d and almost as much as the ss 6500
TWO EGG, FL USA
Post Number: 535
i had the 6500 pushin our 3kws and the 3kw quantum one wasnt too far behind it
Username: Juliob
Post Number: 4390
they drain a lot cuz they're A/B
Username: Nd4spd18
Southeast PA
Post Number: 1455
Dude, get a clue. With two 60 amp fuses, the most that thing can draw would be 120 amps. If it were 80% efficient, the most power it could produce would be about 1400 watts.
4000 watts, yeah right. It's physically impossible.
