Missisng Some Indian Channels
Username: Mississauga
Post Number: 48
I have Echostar 1.2 on 148. I am not getting Sahara (Ch. 624) Zee Guj (Channel 623) and KTv (channel 667).Tried blind scan several times but no luck. Any idea what is wrong
Username: Cartier1
Post Number: 410
YEAH . how the hell we know if u dont say what reciever what bin and stuff like that.
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 1731
Mississauga User: You must be in a "highrise" to get echo 1/2 .
Post Number: 49
It is Viewsat Ultra. Using latest bin released on Apr 7th. No I am not in a high rise. It was set up for 148 since I do not have line of sight for 61.5. No problem with the rest of the channels on this satellite
Username: Nydas
Post Number: 2376
If you are in Mississauga, you would have great difficulty with 148W. Try individual TP scan. I have often had some missing TPs after a blind scan of 61.5, and a TP scan nearly always brings the truants in.
Ideally, of course, you should aim for 62.5W
Username: Nydas
Post Number: 2379
Sorry - typo error. I meant 61.5W
Post Number: 1747
I find it "improbable"to get echo 1/2 from missisauga,first all the highrise buildings and overpases and other man made obstructions,combined with the location and horizon issues.Last I checked it is below horizon from locations farther west than missisauga.Can you confirm it's echo 1/2 your hitting from a ground location.
Username: Crazy_greek
Post Number: 850
Never said that, he/she was located in Canada.Only the username.
Try only a TP Scan.
(tp25) Freq.12574 (Pol V) SR 20,000.
The Channels that you are looking for, are all on this TP.you didn't say anything about Zee Punjabi, Channel 622, are you getting this Channel?
Post Number: 50
Yes I am in Mississauga, Canada. I have had no prblems with Satellite 148 (Echo 1.2) all these years. All other channels on this satellite are working fine
Will try a TP scan
Post Number: 51
Kavin, you are right. I am not getting Zee Punjabi, Ind Music etc.
Can any one familar with Viewsat Ultra let me know how to do TP scan. I tried Channel scan but it says it failed
Thanks
