polypropylene woofer large roll treated foam surround dual voice coil design CONsealer gasket hides mounting screws and stops bass-robbing air leaks frequency response 30-400 Hz RMS power handling 400 watts peak power handling 800 watts sensitivity 85 dB 4-ohm impedance top mount depth 5-3/4" sealed box volume 0.375-1.75 cubic feet 1-year Sonic Electronix warranty
with the box for $99.99 or should i get
Rockford Fosgate RFP2212 12" Punch HX2 Subwoofer:
Two 3" 4 Layer LXtended Voice Coils Coil on Aluminum Former FIBERLock Cone Hyper XTended Pole Piece LXcursion Cast Frame Dual Laminated Progressive Flat Spider BART Surround CONsealer gasket hides mounting screws and provides an airtight seal Aeroport Exhaust Rubber Magnet Boot Dual 4 Ohm voice coils Frequency response 26-200 Hz RMS power handling: 500 watts peak power handling: 1000 watts Sensitivity 88 dB SPL Top mount depth 5-13/16" Sealed box volume 0.8-4.0 cubic feet 1-year Sonic Electronix warranty
for $139.99 also comes with box.
would there be a $40 dif between the two or should i just get the 10" ?
