Need Help - Bose Acoustimass 6 series II
Username: Stephen59
Ottawa, ON Canada
Hi there, I just purchases a second had Bose Acoustimass 6 series II Home Theater System, but all I have is a Sony - STR-D865 surround sound reciever, however I don't think this is a suitable reciever. I am yet to have hooked things up and I am looking for some experienced advise.
Thanks,
Steve
Username: Stephen59
Ottawa, ON Canada
Too bad there's no one in here that has a clue about this!
Username: Divin11112000
Michigan
Post Number: 127
Most on this forum stay away from bose, espically the Acoustimass.
I would imagine any reciever would be suitable for the acoustimass. If your asking if you should purchase a NAD/Rotel/Sunfire amp or something like that, my suggestion would be not to spend the $ on that kind of amp for the acoustimass as it would be wasted.
So all in all I don't see a problem hooking them up to the Sony, although i was unable to find any real information about that model
Username: Project6
Post Number: 13738
The most important thing is to hook them up and listen for yourself.
The determination for its suitability rests upon you and how you experience the particular set up.
If you find that they match well and sound better than your previous set-up, who is to say you are wrong?
Username: Stephen59
Ottawa, ON Canada
Thanks so much, I'm really quite clueless about this stuff, I really appreciate your advise!
