Battery Terminals....Nuts and Bolts? Haha
Username: Afroopuff
Post Number: 402
I don't know if it is just me, but damn I have run into a milion and one problems. Anyway, so heres the latest problem...
I have two amps....1 powering the speakers and one powering the subs. Problem is, the terminal which has the screw comming out of it, is too short for me to get both amps run off of it. One fits nice and snug...but with both on there, i cant get the nut to secure it up back on...
Anyone had this problem?
Is it a standard nut and bolt, or is there something special about it?
Username: Oglejust
Post Number: 1367
its like a square on top if ur talking about the same thing i am
Username: Rovin
My 1 12 Atom...
Post Number: 11249
pix of what u referring to ???? .......
Username: Afroopuff
Post Number: 403
i lost my cable from my camera to the computer...:/ haha sorry...but im sure someone else has had this problem...or maybe its just my car AGAIN because it is the most difficult car to put a system in
Username: Johnfiac
151.9db Dail... My wangers b...
Post Number: 2206
Mike, i think i know what your saying. You dont have post's in your battery but you have Bolts instead.... You can either buy longer bolts (stinger sells them) or you can buy POST TERMINAL's that screw into the battery, then you can just buy some battery clamps to use.. hope that helps.. (if not.... Get a bigger gauged ring terminal and soder\clamp both wires into the one instead of using 2 (thickness of 1 now :-) )
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11858
you need new terminals and battery posts that allow for longer "bolt" threads.
www.partsexpress.com
order up some pretty gold ones. they aren't that expensive.
