Best subs for Hip Hop/ Rap music
Username: Fearthisskyy
Carrollton, Texas United states
Post Number: 20
What are characteristics should I look for in subs for Rap/Hip Hop music? What are some recommendations for subs? Anything will help, thanks.
Username: Trey4sports
Post Number: 947
gotta have a budget bro. i would buy Fi Q's or Audioque HD3's
Post Number: 21
my bad, budget is $200-250 per sub.
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 976
What kind of power are you looking to run??
Most likely Fi will be able to help you out. Check them out at www.ficaraudio.com
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12085
LOL..L7's
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 831
ide say 2 15"SD2.5's (you wont be dissapointed) www.audioque.com
^^^my choice
or for a little more a 2 15" Fi.SSD
www.ficaraudio.com
Post Number: 22
I checked out the Fi Qs and they need so much power to run a single sub. I was wondering how big the difference would be having one Q15 instead of two Q12s. I don't think I would want 2 15s since it'll take up more room.
