Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 608 Registered: Nov-06 | I believe Steve Meade has one just like it. He had to use a fork truck to move it. I think it was over 200lbs. anyway check it out. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D260105447966 quite pricy but 15000 watts! |
Silver Member Username: SplsqChesterland , Ohio USA Post Number: 148 Registered: Mar-07 | its not worth $18,500 get an SUV and drop like 10,000 in ur system and thump as hard. |
Silver Member Username: SkiesCourtenay, British Colu... Canada Post Number: 561 Registered: Aug-05 | Wow... Over 100% efficiency. Interesting. |
Bronze Member Username: FootballaPost Number: 30 Registered: Apr-07 | wow. |
Silver Member Username: Dsmith07NC Http://com4.... Post Number: 648 Registered: Jun-06 | what kinda charging system would u need with that? |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 610 Registered: Nov-06 | over 350A |
Silver Member Username: SkiesCourtenay, British Colu... Canada Post Number: 563 Registered: Aug-05 | Apparently it only draws a max of 300A. Dual 300a alts maybe. You only need 350a alt but I don't think they make higher than a 300. |
