5 1/4 speaker question
Username: Solid8447
Post Number: 14
What is the best 5 1/4 speakers because my car just has four 5 1/4 speakers. I have about 250 to 300 for them. What are some ideas. Thanks
Username: Adddisorder
West palm, Florida
Post Number: 4493
are you going to be useing an amp?
Username: Delsole
Post Number: 1275
cut out your doors etc. to make room to mount 6.5's
Username: Solid8447
Post Number: 19
what wouild i use to cut it with
West palm, Florida
Post Number: 4500
dont cut it thats unnecessary 9times out of 10. depends what your looking for in a speaker. high quality sound and strong midbass i would do 6.5 or 7" you should be able to use a peice of 1/2" MDF and cut out a hole for the new speaker and place it over the existing hole. and that is basically that.
