Bronze Member Username: QuirkySA, Texas Post Number: 91 Registered: Feb-07 | if i have an 1200.1 kicker amp, can i use an 80A fuse on my installation kit? if not what should i switch 2? here's the kit im thinking of buying for it-$80 http://www.circuitcity.com/ssm/Specifications-of-Tsunami-Amplifier-Power-Kit-AMP 850BL/sem/rpsm/oid/71672/rpem/ccd/productDetailSpecification.do#tabs |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 307 Registered: Jan-07 | well i dont know for that amp exactly,but for the zx1000.1 you need a 100A fuse and for the zx1500.1 you will need a 150A fuse. so if my calculations are correct you will need a 120A fuse... could be wrong do, but i think that kicker amps come with a fuse, at least the zx series comes with fuse. |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 308 Registered: Jan-07 | and go to knukonceptz.com for amp kits and accesories for a better price... |
Silver Member Username: Dakangofkrunk16Earth Post Number: 489 Registered: Mar-07 | 4 gauge is rated at 125 amp and below so 100 should be fine also the amps fuse rating is 100a so there ya go |
Bronze Member Username: QuirkySA, Texas Post Number: 92 Registered: Feb-07 | k thxs |
Bronze Member Username: Dj_007Carlisle, KY US Post Number: 78 Registered: Dec-06 | use a 100 amp fuse or braker.. that away its actually helping..} |
Bronze Member Username: QuirkySA, Texas Post Number: 93 Registered: Feb-07 | nice, i just bought the 4 gage kit they sell for $50 plus it has an 120A fuse. "why" u saved me alot of $ thxs. |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 311 Registered: Jan-07 | no, problem just send the profit to my paypal... j/k lol |
