Hello there, I converted the Genuine Pansat 2500A into Pansat 2700A. I just want to know if I should use the clonesafe bin or the Genuine Pansat 2700A bin for this reciever. Any help be great. Thanks.
Use the clonesafe first...in that way you will be trying on a safe way, using the clonesafe it doesn't matter if you have a clone or a original receiver.
The clone safe won't hurt the original receiver but using the geniune bin in a clone receiver then for sure it will damage that receiver
