hi, i just bougth a CW600p, and i dont know the steps to download a files or how to enter keys ,please if anyone know how ,please tell me how step by step, thanks.
1) Connect the receiver to the PC via a Null Modem Cable. 2) Turn on the receiver and press "POWER" button to enter standby mode. The LED dot will blink. 3) Run the uploader utility on the PC. 4) Select the "Download S/W" Radio Button. 5) Select the appropriate Communication Port. 6) Press the folder icon to open the file Selection Dialog. 7) Select the "CX-Loader" binary file for the receiver. 8) Click the "Start" Button to download the loader software to the receiver. 9) Wait for the download process to complete. 10) Press the folder icon to open the file Selection Dialog. 11) Select the firmware binary file for the receiver. 12) Click the "Start" Button to download the firmware software to the receiver. 13) Wait for the download process to complete.
ok u gonna put in latest bin....after u do that you will go to antenna settings. First off, do a factory reset....then go to antenna settings. Locate 61.5 and when select it, it automatically should tell u 61.5 found on lnb1...then u going to do auto scan. after you do autoscan...go on normal channel screen and press f1-000. That will enable the autoroll patch. After that go to scifi channel and let keys autoroll.
go to the site lk posted it is the best site for this box you will get great help the new bin for cw600s is 134i think the dat is 04082007 for the cw600p the new bin is 140 dat 04082007 bins are working great keep up the good work cw and team ill get you the info *Start HERE, New Cap.Works Premium Owners*
For people just getting a CaptiveWorks Premium receiver, it may be confusing what bins to load, and what proceedures to follow. My friend just got one, and I told him to read the forums here at Future. He complained to me it was hard to figure out what files to load and in what order. I checked myself, and I can see how someone could get confused. Hope this helps.
Note - This information was originally covered in this post by LedHead, http://www.future-fta.info/Forums/sh...34&postcount=8, however the information has been updated here (ie: new files, loader, etc.)
1. Get the current 1.06 loader here: http://www.future-fta.info/Forums/sh...ad.php?t=37252
2. Download the latest bin from here (top bin; highest bin number): http://www.future-fta.info/Forums/fo...play.php?f=207
3. Load the latest bin (from above) with the current loader (from above) as per these instructions:
Open 1.06 loader, select the latest bin in the "File" bar across the top. For Options, select Download S/W. For Select a port, choose your COM port (usually 1).
Prepare reciever: Turn off and attach the null-modem cable between the receiver and the computer serial port. Turn back on. With the CaptiveWorks Premium receiver on, press the front power button and hold it. While holding it, turn off rear toggle switch, then turn on again while STILL holding front power button. You will see "boot" on the front display. At this point, remove your finger from the front power button and press "start" on the 1.06 loader. Wait for the receiver to display "-end". At this point, turn reciever off at rear switch, and then turn on again.
4. Perform Factory Default: Using Remote, press: Menu, Installation, Factory Default, All, ok, yes, ok.
5. Load the ICON bin found here: http://www.future-fta.info/Forums/sh...ad.php?t=23504 (ignore the 1.13 bin found with it)
6. Load the NEW Long Channel Name Bin found here: http://www.future-fta.info/Forums/sh...ad.php?t=41590
7. Factory Default, and then setup the receiver:
Select language Select GMT time (-5.00 is Eastern), summer off in winter. Search channel
Set DiSEqC switch ports and scan. Upon completion, press F1 key (you will notice an "h" on the front panel display), and "000" to enable the patch. (repeat with "555" to enable cardshare). Allow time for keys to roll.
Setup up OSD options:
Menu System Settings System Channel NO. - SID Key Update Message - Off B**andD**hnet Full Name - ON
Menu System Settings OSD Display Icon - YES Auto Exit Channel List - YES EPG Style - NEW (recommended) Channel List - CH 10 (appears when you press OK button, lists 10 channels, or 24)
8. *Optional* Loading a custom picture/Jpeg You can load a jpeg picture (up to 64K in size) the same way you load a bin, in boot mode. Then you reset the receiver and activate the custome background like this:
Menu System Settings OSD Background - User Logo
For tips on how to use the Universal Remote: http://www.future-fta.info/Forums/sh...ad.php?t=22062
For a guide to the menu and features of this receiver: http://www.future-fta.info/Forums/sh...ad.php?t=22238
For information on cloneing one CW premium to another CW premium: http://www.future-fta.info/Forums/sh...ad.php?t=40425
For general loading/scanning info: http://www.future-fta.info/Forums/sh...ad.php?t=37455
All other CW Premium Stickies can be found here: http://www.future-fta.info/Forums/fo...play.php?f=206
This info helped out my buddy, and I hope it helps you to. Thanks to Ledhead, Arboristman, Tumpy, and SlckDck1 for their contributions.
elbaji youssef wants to receive 61.5 W. There is very good information above. I will stick to missing information. You need to have a Dish pointing to the Echo 3 satellite at 61.5W. Yousssef, if you are taking over an existing satellite installation, chances are that it will be pointing to 110W/119W (DN) or 82W/91W (BEV). If that is the case, you will need another 18" dish pointing to 61.5W and a switch to complete the connection. There are elaborate instructions for connecting DN/BEV LNBs to an additioanl LNB via a switch. If you are not at all insterested in the DN or BEV American channels, you can use your existing Dish and turn the Dish to point to Echo 3. If you do not have a Dish, then any 18" Dish with a standard LNB will do. Wish you happy viewing of International channels.
