Wiring question...
Username: 2pacalypse1971
Sandusky, Oh
Post Number: 301
ok i'm thinking about gettin 2 kicker cvr 15's (dual 4 ohm) and i'm really interested in the rockford p10002 amplifier with specs of 250x2 at 4 ohms, and 500x2 at 2 ohms, and 1000x1 watts at 4 ohms bridge, if i get the dual 4 ohm kickers, how do i wire it to get 4 ohms bridged, or can i not do that???
Username: Kaerfpl
Spencerport, NY USA
Post Number: 495
check it out: http://www.the12volt.com/caraudio/woofer_configurations.asp
Sandusky, Oh
Post Number: 304
that really didnt' help me out i knwo hwo to wire everything for like a 1 ohm load and a 4 ohm load, it is just the ''bridge'' part that confuses the hell outta me
Username: Waterboy2289
Martinez, Georgia 2 18 SX w/ ...
Post Number: 196
the bridged part just has to do with what channels you connect the subs to on the amp......they will be marked on the amp and in the amps manual.....it is very simple....trust me
Sandusky, Oh
Post Number: 305
so on the dual 4 ohm sub, would i connect both positives and both negatives, or would i connect a + to a - and then run the other 2 +'s and -'s out, i'm stil a little lost
Georgia, DiRtY SoUtH ... 2 18 SX w/ ...
Post Number: 200
this should explain it:
http://www.imagehosting.com/show.php/454405_twodvc4subswiredto4.JPG.html
Post Number: 201
just connect the (+) from both subs and the (-) from both subs to the same terminals on the amp (obviously the designated bridged terminals)
