Subwoofer works, but speakers dont
Username: Gh0st_31
FL USA
Post Number: 358
I got my CD5000, installed it and my subwoofer plays fine but there is absolutely no sound coming from any of my speakers. I have tried about 4283948329 times to fix this but no luck. Unfortuately I'm thinking that the internal amp is shot. And everything worked fine before. bought it new off cardomain. I tested the speakers on a home unit and they worked fine.
Username: Th3pwn3r
Post Number:...
Post Number: 1802
Is there a feature to turn on the internal amplifier?
Username: Carguy
Post Number: 6085
You need to list your configuration. Do you have external amp? Are the speakers powered by the HU or via an amp?
Username: Smoke05
Tucson, Arizona U.S.
Post Number: 313
check the connections for the speakers on the back of the HU... maybe
Username: Gh0st_31
FL USA
Post Number: 359
no im told theres no internal amp turn off feature. i looked through the handbook and saw nothing speaking of the internal amp. I have one external mono amp to my sub. My speakers are powered by the headunit.
Username: Gh0st_31
FL USA
Post Number: 360
ok now my headunit wont even turn on. I rewired it but the fuse in the front of the car keeps blowing and when i touch the two yellow wires (with the fuse) my speakers go in. :-(
