Box question
Username: Dtp2007
South, Jersey
Right now i got 2 audiobahn 700rms each in a aderalin bandpass box with hifonics amp 1600rms in 1ohm monoblock(probally overrated) in a 93' crown victoria by the way had it own sound dampen stock(which i did not know)
Would a port box be better?
I listen to rap and enjoy deep bass, right now i get good deep bass on some song but find myself adjust the settings all the time, cuz i guess the freq the bandpass allows
Is bandpass for suv and would i get more from setup if i went ported and utilized my trunk cabin space
Username: Oglejust
Post Number: 1348
ported would be better
Username: Dtp2007
South, Jersey
why??
A pic is worth 1000 posts!!
Post Number: 5429
More efficient design. You'll get more output from your subs in a vented enclosure. Sealed is more of a sq design. Audiobahn is not sq.
Username: Dtp2007
South, Jersey
ok then so i should get the biggest box my sub are recommend at and it should be tuned at what? I listen to rap and like deep bass
Any boxes u can recommend?
Username: Spkrman
Chi town, IL U S A
Post Number: 376
www.spkrman.com
or if you are cheapin out: www.ebay.com
Username: Dtp2007
South, Jersey
what do u think about this box:
http://caraudiofactory.com/double-transmission-line-advanced-slot-ported-p-126.h tml
