Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 596 Registered: Nov-06 | I have one 15" JL AAUDIO W3v2, which is rated at 500 watts RMS, and one 15" JL AUDIO W3v1, which is rated at 400 watts RMS. They are both dual 4 ohm subs. They will be in a ported box around 3 cu.ft. per sub. What would be the best wattage to go with for the two, 800-1000? What would be the best amp choice? I was thinking of a Crossfire VR600D or possibly the VR1000D. The 600D is rated at over 900 watts RMS @1ohm at 14 volts. I would like to run at 1 ohm but if it would be better at 4 ohms, because of factory electrical system, than let me know what amp would be good fot the 4 ohm operation. I am thinking of getting a HO alt but not sure which car it will go in. I will also be using a PG TBASSCUBE in this system. Any suggestions? I know the two subs are different but only cosmetically and their power handleing abilities. Thanks for your help/opinions! |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 599 Registered: Nov-06 | BUMP!!!!!!! |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 602 Registered: Nov-06 | BUMP AGAIN!!!!! Nobody can give me their opinion at least? |
Silver Member Username: MgbcsLincoln, Nebraska Post Number: 847 Registered: Dec-06 | Well, you have a lot of options you listed there. I would say that the Crossfire is a great choice. |
Gold Member Username: CtmikeCt. Post Number: 3874 Registered: Feb-06 | i'd just go with the 600, crossfire underrates their amps and it'll push those subs nicely. |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 603 Registered: Nov-06 | Does anyone know where there is a VR600D for sale? Thanks much for your input. |
Silver Member Username: MgbcsLincoln, Nebraska Post Number: 848 Registered: Dec-06 | http://www.woofersetc.com/index.cfm?fuseaction=page.display&page_ID=14&category_ ID=3&mfg_account_ID=25&sort=high Seems kinda spendy tho |
Gold Member Username: CtmikeCt. Post Number: 3875 Registered: Feb-06 | woofersetc.com sells them for $320 shipped. no 600's on ebay, but there is a 1000 going at $203 right now, ends in less than a day. |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 604 Registered: Nov-06 | Thanks for your help. If you find more for less $$$ than post please. |
