EQ??
Username: Skibum12189
Cleveland
Post Number: 436
hey guys, I'm thinking that after working for a bit this summer ill have what i want which includes my premier 680 HU running a zx1500 pushing 2 12" ssds, a zx450.2 pushing crystal sscs 6's, and then infinity kappa coaxials off the HU for rear fill. I like to have my sub hit most of the stuff under 100-125, and i wanna have my rear speakers play quietly enough to not distort even up to like 55/62 on my HU while my front speakers can play loudly cleanly, and a bunch of other settings i like....
Would a trunk mounted EQ help me to tune everything the way i want and which EQ is one of the most popular/which should i get. Are they real difficult to install??? THanks guys
Username: Spkrman
Chi town, IL U S A
Post Number: 378
an EQ is nice.
If you are smart enough to hook up an amp, you can install an EQ in 5 minutes.
One word of advice, mount the EQ up front, the absolute last thing you want is to go back and forth to teh trunk while you make adjustments... thats about as bad as it gets.
Cleveland
Post Number: 437
what would be a good front mount eq to get?
Username: Oglejust
Post Number: 1349
audio control eql is what im gonna get
