Quick port question.....
Username: Hootz
Saskatoon, Saskatchewan Canada
Post Number: 272
For net internal volume, do you subtract the area of the material used to make your ports? Or do you subtract them plus the volume of air inside the port?
A pic is worth 1000 posts!!
Post Number: 5400
Thickness of the port material is negligible at best, and I always included the port area in my box's volume design. My $.02
Username: Hootz
Post Number: 273
bump
Username: Shootz
Yorkton, Saskatchewan Canada
You times the length by width by volume to get the volumeUpload
Post Number: 5424
Here you go Brett.
http://www.diysubwoofers.org/faq.htm
I've never built a slotted box though, if that's what yours is.
Username: Hootz
Post Number: 274
Lol^ For all the guys who build vented enclosures on here, you'd think this would be a pretty simple question to answer. Thanks for the reply Paul....ANYONE ELSE?! I'm looking at a difference of a cubic foot here, and as far as I know, you DO subtract the volume of air inside the port. But I'd like to know for sure before I glue and screw. Someone PLEASE?!
Username: Hootz
Post Number: 275
Oh sh!t thanks paul, you posted that as I was typing my last one out. Yeah mine is slot ported, I used bassbox pro to calculate everything and it said the same thing so I'll just go with that assumption I guess
Post Number: 5426
Yeah somehow the way I worded my first post it sounded like I included the port area in my box's overall volume. What I should've said was I took the port's volume into consideration in my overall box volume. It might of been the rum.
