Username: Mgbcs Lincoln,
Nebraska
Post Number: 785 Registered: Dec-06
Saturday, April 07, 2007 - 19:54 GMT Hey...I am making an ordered list for someone and need to know what size fuse to order with the knukonceptz wiring kit. 60/80/100/150/200/250/300A?
Username: Wrencher Brighton,
Illinois
Post Number: 4 Registered: Apr-07
Saturday, April 07, 2007 - 20:13 GMT What amp are you using? Don't you have the owners manual that tells you what size fuse to run? It also depends on what the total impedence is on your amp.
Nebraska
Post Number: 788 Registered: Dec-06
Saturday, April 07, 2007 - 20:25 GMT It's for a small 4-channel and a ROckford t20001bd.
Username: James1115 Use a simple...
Post Number: 10057 Registered: Dec-04
Saturday, April 07, 2007 - 20:40 GMT take the fuses in the amp add them up and whoala!
Nebraska
Post Number: 789 Registered: Dec-06
Saturday, April 07, 2007 - 20:49 GMT 250 it is. Thanks!
