Where to buy wood?
Username: Highstone
Post Number: 379
hi guys i wanted to know where can i buy 3/4" MDF.. and standard sheet is 4x8 feet right???
thanks
Username: Logan__tille
Http://com4.runboard.c..., Imortal Box ... Logan116600@...
Post Number: 6792
menards lowes home depot lol
Username: Highstone
Post Number: 380
humm i checked my local lowes and Home depot i didn't see it there... do they have to order it...
Post Number: 6793
No, ask them. They should take you to it.
Username: Highstone
Post Number: 382
hummm is it in a secret stash room.. lol ok i'll do that .. thanks..
A pic is worth 1000 posts!!
Post Number: 5296
My lowes carries mdf in full sheets and 1/4 sheets at a slightly higher cost. Very nice if you don't have a truck.
Username: Highstone
Post Number: 383
do they cut it for free?
Username: Matt12490
California USA
Post Number: 2155
At my home depot it is 25 cents per cut
Post Number: 5301
I never needed them to cut anything. Not sure if Lowes charges or not. I really wouldn't want some pimple covered squirt cutting my wood anyway. I've been using power tools for 20 years. I hate it when some 17 year old says "Sorry, you can't operate that saw, you're not qualified."
Dweebs.
Post Number: 6825
LOL^^^^That pisses me off to
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 1894
Chip and Dales...
Username: Mercsable
Kalamazoo, MI USA
Post Number: 86
yeah I get usually have lowes cut it for me. I draw out exactly where the cuts need to go and they are still usually too stupid to figure it out. Plus all the cuts are usually 1/4" off...dumbasses
Username: Tremor1127
Fi Car Audio has got m...
Post Number: 1294
shut up logan, your like 17 too... :-)
Username: Highstone
Post Number: 391
lol... i see that no one like to get their wood cut at the store... humm.. but i have no choice.. cuz i have no tools never used those tools... soo yeah i guess i gotta trust those pimple faces...lol
Username: Smoke05
Tucson, Arizona U.S.
Post Number: 284
well if you are going to have them cut your wood, be sure to have all the right measurement you need (counting the 3/4" of the mdf and the width of the saw, try to be there when they cut your wood (lol) and be sure that the guy doin it isnt a retard...
BTW in my local Lowes you get 2 cuts for free and any extra one is just 20 cents. let us know how accuarate they were. good luck
Username: Highstone
Post Number: 396
hey thanks.. and sure i'll let u know ...
BTW how much should a sheet cost me ??
Username: Dlavante
Tigard, Or USA
Post Number: 46
$20-25ish
Username: Highstone
Post Number: 398
who is cheaper ..lowes or home depot...
