Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 164 Registered: Sep-05 | ok guys. i have been goin back an forth on what kind of box i wanted in my truck. so finally i decided on putting the box as my center console. i can fit one 12 max. i have a box planned that is 2.14 cu. ft. tuned to 33hz. i have an old power acoustik amp around that i wil be using to power which ever sub i get. the amp is the A2400DB. yes i know. not the best amp. but what sub to get for when i upgrade in the future. i already have a HO alt on the way from iraggi. its the 280 amp amputator series alt. i was looking at the fi Q and bl. any others that would have some sql but still get hella loud? looking to stay within 350 bones. |
Silver Member Username: 04redmach1Columbus, GA USA Post Number: 487 Registered: Mar-06 | $325 shipped for RD Alpha 12 D2 Kevin lowhz01@yahoo.com |
Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 165 Registered: Sep-05 | whats RD's website so i can check em out. |
Silver Member Username: JblanfordPost Number: 699 Registered: Oct-06 | www.rdaudio.net go with the alpha |
Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 166 Registered: Sep-05 | the alpha over both the fi q and the bl? anyone second this opinion? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1337 Registered: Jul-06 | Well I would take the Fi but that's cause I've never heard an RD..... |
