Slightly OT
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 2427
ok, I am going to need an amp wiring kit for the 300watt amp I am going to be using for a temp amp, but it also needs to be able to handle the 425watt one once I get it...who makes a good one, and where can I get it...also, a lot of them just say what guage they are, so what guage do I need?
Post Number: 2428
oh, and just for a funny, I went by Autozone and looked at their off brand name amps...the smaller 2 channel one says 250 watts.......rms is only 18watts per channel....same thing for the big one, 4 channel 500watts...rms is still ony 18 watts per channel...how can they get away with that crap?lol
Username: Logan__tille
Http://com4.runboard.c..., Imortal Box ... Logan116600@...
Post Number: 6817
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=14
Username: James1115
Use a simple...
Post Number: 10044
so it needs ot be able to handle 725? or 425? for 725 I would go 4 ga and for 425 8ga is fine.
Post Number: 2429
425, the 300 is a temp amp then I'll put it aside and use the 425 once I get it.
Post Number: 2430
logan, that one looks kinda cheapo, how good is it?
Username: Rovin
My 1 12 Atom...
Post Number: 11196
y buy a temp kit if u know ur upgrading in the future
but a kit now which will be able to take the heavy loads later on ......
Post Number: 6818
Its a good kit.
Post Number: 2431
not a temp kit, a temp AMP...I'm gonna use the 300 watt amplifier until I get the 425 watt amplifier. Just wanted to make sure the kit will handle either one...
thanks for the link logan.
Post Number: 6820
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11828
this tells the wire size you need based on the power you have
http://www.the12volt.com/info/recwirsz.asp
