I just noticed that the Polk Adio FXi3's are rated at being able to handle 150 watts while the larger FXi5's which is the next model up and cost more are rated at only 125...is this a possible misprint in the specs? You would think that the larger speaker would have higher power handling, or atleast the same, but not lower...
FXi3: Recommended Amplifier Power 20-150 w/channel
FXi5: Recommended Amplifier Power 20-125 w/channel
