Head Unit with no remote wire to amp?
Username: Ridethelitning
I have a Legacy head unit (going in a soft top Tracker-am not going to put an expensive unit in it) with no remote wire on the harness. I have a small amp that I am going to install with it. How do I cut the amp on and off? The amp does have a remote wire terminal.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2842
sounds like you'd be better off with the factory system.
Username: Joe718
lol that is true but you can get switcehd power from the same line that is used to turn the radio on and off with, the only thing is the amp wii stay on even when the stereo is of but it will cut on and off with the ignition
