hi i'm starting to set up my home theater system. am getting this used sony ES 5cd changer (CS75ES) which is in pretty good shape. any recommendations or advice??
Correction: sorry it's C75ES and not CS75ES.
Mr. V
What use is a cd changer in a home theater?
You'll need a dvd.
You are at square one on the learning curve, friend. Best bone up fast.
well my bad.. i meant i'm going to be using this set up for my music as well as a home theater. that's why the cd changer. any reviews abt C75ES???
