Alpine decks
do the alpine decks that have the v-chip or v something really need its own seperate amplifier kit? i read that they have a small internal amp in the deck itself and that it pulls too much current, that's why it needs its own amp kit. is that true?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2154
Vdrive, and yeah not a "kit" so much but they do need a 10AWG line, fused, directly to the battery terminal post. They draw a solid 15A of current, which is over 100wRMS total.
26wRMS x 4 to be specific.
Username: Oomrkenoo
what happens if you dont wire it with 10 gauge to battery? can it cause ur amp and sub to not power?
Username: Glasswolf
Post Number: 3082
What happens is the amp in the head unit will draw more current than the dinky wiring in the car is designed to handle, and the wiring will pretty much melt, and possibly cause a fire behind the dash.
At best, you'll cause clipping in the amplifier, and distortion which will damage the speakers connected to the radio.
Username: Oomrkenoo
Post Number: 9
can anyone provide me with how to wire the vdrive with 10 Gauge wiring? I dont know how you can hook up power and ground to the deck...
Username: Glasswolf
Post Number: 3121
maybe you should let a professional do that
Username: Jonathan_f
GA USA
Post Number: 79
You wire it just like an amp. Run a 10 gauge wire from the battery terminal, through the firewall, and connect it to the head unit's power input. Same with the ground, mount it to the chassis.
