New member Username: Becky76Post Number: 1 Registered: Mar-07 | Has anybody any experience with this new remote? www.x10iconremote.com I used to own a harmony (550). |
Silver Member Username: ClaudermilkCA USA Post Number: 455 Registered: Sep-04 | Nope. Haven't heard of it. Looks like a few good ideas depending on your setup. For me, I'll stick with my Harmony 880. Most of the features those guys are touting either I have covered elsewhere or prefer the Harmony's method. |
Bronze Member Username: HodedofomeTX USA Post Number: 48 Registered: Dec-06 | For that price a Harmony brand or Universal Remote brand would be better. This is an obscure brand that doesn't have the mainstream support that Harmony and Universal Remote enjoys. You can do a lot more with Harmony's online setup and Universal Remote has a ton of support available on the web. |
Bronze Member Username: Josh1005Norfolk, VA U.S.A Post Number: 41 Registered: Mar-07 | harmony 880 all the way i love it and wouldnt change it for anything setup is simple and really makes it easier to control everything |
Bronze Member Username: Floyd_1977Plainfield, IL USA Post Number: 71 Registered: May-06 | JP1 remotes are also a great option. They are generally about a tenth the price of Harmony remotes and provide just as much flexibility. |
Silver Member Username: Divin11112000Michigan Post Number: 122 Registered: Dec-04 | I have the harmony 880, and I love the remote. Almost don't know how i could control my system without it. Super easy to setup, and once it's done you don't have to worry about it. Although if you do need changes takes only a few minutes to update the changes and your good to go again. |
