Bronze Member Username: LowganPost Number: 23 Registered: Feb-07 | I just want to be absolutly certain about an amp before i buy it, there kinda expensive. |
Gold Member Username: Bump05CashMoney, 15 Hd3 USA Post Number: 1036 Registered: Aug-06 | i can get you a memphis 4kw perfect for that sub depending on ur coils... for 900 which is a sick deal cause there brand new for 1600 |
Bronze Member Username: LowganPost Number: 24 Registered: Feb-07 | i need one that will run dual 1 Ohm voice coils. |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 419 Registered: Nov-05 | if u have the money buy a kicker kx2500! |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4346 Registered: Dec-05 | something putting more than 2k for sure. |
Gold Member Username: 420alldaylongPost Number: 1318 Registered: Sep-06 | Budget? |
Platinum Member Username: RovinMy 1 12 Atom... Post Number: 11131 Registered: Jul-05 | from what i read reg BTL takes 2000\2500 with ease so a modded 1 should feel good with 3000-4000wrms go ebay ...... |
Silver Member Username: KillswitchjdPost Number: 370 Registered: Apr-06 | two amps that put out 2000x1 at 1 ohm, maybe 2 orion 2500d's to go big |
Gold Member Username: Bump05CashMoney, 15 Hd3 USA Post Number: 1037 Registered: Aug-06 | I can get you brand new kicker amps memphis amps digital design amps let me know eastbayafi05@msn.com |
Gold Member Username: 420alldaylongPost Number: 1322 Registered: Sep-06 | AutoTek MM4000.1D |
Bronze Member Username: LowganPost Number: 26 Registered: Feb-07 | my budget would be about 800 dollars. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 1705 Registered: Jul-06 | Either save up another 100 for that memphis or buy a used amp. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1206 Registered: Jul-06 | There is a guy selling an american bass VFL 200.1 for $515 on caraudio.com: http://www.caraudio.com/forum/showthread.php?t=218147&page=3 That amp will do 3000 watts. He had two and I bought one ![]() |
