Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 749 Registered: Dec-06 | http://store.realmofexcursion.com/ i have a Earthquake PH2000W/D1.1 putting out 1000rms and i was wondering how this alternator would do? is it the right amperage? and is there better for the money? |
Gold Member Username: StnorrisRE SX 15, IA US Post Number: 2116 Registered: Apr-06 | need a new link.... when u get an alternator u should save ur money up and get a big one the first time, then u have room for upgrading. get a 180a at least if at all |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1194 Registered: Jul-06 | and go Iraggi or Ohio Gen |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 750 Registered: Dec-06 | the one in the link is an Excessive Amperage 200A GM Small Case. its about 300$. does iraggi have a website or is it just on the ebay store site? how much do you think an ohio gen cost? (200amp) |
Gold Member Username: StnorrisRE SX 15, IA US Post Number: 2119 Registered: Apr-06 | compare the prices on irragi and excessive of the 200a alts and the power they put out idle...then make ur decision out of those 2 |
Gold Member Username: BernymacCambodian Post Number: 2336 Registered: Sep-04 | Everyone makes their alternators differently. I would pick out a company that could give me what I want. If you play your beats when driving, then iraggi is for you, if you like to play your beats at stop lights or parked, HO alts or ohio gen is for you. So yeah thats just my 2 cents. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1196 Registered: Jul-06 | Ohio gen are great but expensive. Iraggi are good alts at good prices, and make sure you get the amputator series. The idle amperage is just as important as the regular amperage. Watch it with the EA alts, all the ones I have seen don't have a real impressive idle amperage. |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 751 Registered: Dec-06 | hows the dominator series for iraggi? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1200 Registered: Jul-06 | not as good. Lower idle amperage. |
Gold Member Username: 420alldaylongPost Number: 1313 Registered: Sep-06 | When you get a alternator ask these question. Will it fit? Whats current rating? Current drop when alternator heats up? Current at idle RPM? Current at highway RPM? |
Gold Member Username: 420alldaylongPost Number: 1314 Registered: Sep-06 | http://www.highoutputalternator.com/ |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 753 Registered: Dec-06 | im kinda on a buget so would this alt be alright: http://cgi.ebay.com/ebaymotors/220amp-Dominator-Series-Iraggi-Alternator-Chevy-G MC_W0QQcmdZViewItemQQcategoryZ33573QQitemZ7963120257 or should i get this one: http://cgi.ebay.com/ebaymotors/220amp-Amputator-Series-Iraggi-Alternator-Chevy-G MC_W0QQcmdZViewItemQQcategoryZ33573QQitemZ7963120240 ide rather get the first on if it will work. also if i do get this im asuming that i will have to upgrade the big 3 right? also will a stock battery be fine? i really dont want or have the money to buy a new one but if i have to then i guess i will. thanks |
Silver Member Username: Volfenhagking160015 SSD Wangin, Shawano, Wis... USA Post Number: 496 Registered: Oct-06 | when you get a high output alt do u need a better battery 2? |
Gold Member Username: CtmikeCt. Post Number: 3744 Registered: Feb-06 | second alt., the amputator. and yeah throw in a good battery and do the big 3 and you'll be set. |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 755 Registered: Dec-06 | didnt bump |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 756 Registered: Dec-06 | what kinda battery should i get if i really need one. i want one that will last but not o expensive |
Silver Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 757 Registered: Dec-06 | and would it work with the dominator series or is that just a bad idea? |
Gold Member Username: CtmikeCt. Post Number: 3746 Registered: Feb-06 | either will work but from what i hear the amputator is the better of the lines and the one i plan on buying next. as far as batteries the only one's i personally used is a yellow top but am getting kinetiks next. pricier but worth it. remember do it right the first time even if it might cost more. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1216 Registered: Jul-06 | Get the amputator. You don't have to get a battery, a stock one will work. |
