New member Username: Tobymaye2
Post Number: 3 Registered: Mar-07
Posted on EVerytime i get new 12"s the one on the right side ends up blowing? |
Silver Member Username: Killswitchjd
Post Number: 367 Registered: Apr-06
Posted on reset all the levels on amps and hu. then check the subwoofer wiring against a diagram of the right wiring. |
Post Number: 5 Registered: Mar-07
Posted on yea i have did all of that and the wiring is right and reset everything |
Silver Member Username: Kaerfpl
Spencerport,
NY
Post Number: 494 Registered: Jun-06
Posted on probably faulty wiring. Go and inspect everything and make sure everything is in the correct place and secured. |
