ok after the first time i checked my wiring eveyrthing seemed to be fine... the first time it happned my amp was clipping , i would have it up it would cut out, i turn radio off and on and it came on, it did that like 8 times over a period of time, i didnt think anything of it... then it did it, i smelt the amp and it dont put anything out, it illuminated like the lighting on the amp, but no lighting on the power button, maybe i had the gain set to high, or idk what happned, but could it be an internal fuse? if so is the internal fuse easy to find , pic of it? thanks for any help.
