So wat kinda RCA cables u guys running to your sub amp?
Username: Oaktowncrazyd
East Oakland, CA
Post Number: 23
so wat kinda RCA cables u guys running to your sub amp?
Username: Carguy
Post Number: 6004
What do you mean what kind? Are there more than one? Just kidding.
If you're wanting to know what's best, then use twisted pair RCAs. They're not that expensive and work well with noice cancellation.
Username: N2audio
Lawrence, Ks USA
Post Number: 1228
shielded twisted pair. $10 for 17'. Boss brand.
been working perfectly for 5+ yrs now. Never a noise issue.
Username: Djbeanpole
Naptown, Indiana USA
Post Number: 346
Regular RCA!
Username: Adddisorder
West palm, Florida
Post Number: 3773
i use PG ARX twisted and sheilded
Username: Carguy
Post Number: 6007
Whatever you use, don't get suckered into buying one of those "monster" cables for $150. Useless and waste of money.
Username: Malic
Oklahoma City, OK U Essay
DB Link, only because I get 20 ft. RCA's for like 5$
Username: Bradddgeezy
Fort Wayne, IN USA
yeah Isaac. I had a friend get suckered into buying those monster cables. They were like $115 and the guy at the store said that the quality would be a lot better and the bass would be even better. He installed them and well... absolutely no difference...that guy made hella comission that day
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11725
cables are cables. They won't make any audible difference to a system if you just pick a decent pair of shielded or twisted-pair cables.
Username: Theivan
Dawson Creek, British Colu... Canada
Post Number: 28
glasswolf is right there :-) just dont go with a cheap walmart pair for your home system....i had those and went to a good pair, huge difference.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11739
knukonceptz has very good, affordable cables.
Username: Killswitchjd
Post Number: 362
in cheap pairs, the end peices can come off easily. Get a decent brand, but monster cables of any kind are over priced and they suck. avoid them (guitar, car audio, wateva)
Username: Illuminator
Post Number: 4881
Yeah, as long as they hold together (especially at the connecting ends) shielded or twisted, they're fine. :-)
Username: Sheriff
Post Number: 270
Blue cables
Username: Downlo
Hempstead, New york Usa
ive used the cheap ones ( $7 or so 12') but in a geo tracker, used the black jacketed radioshack ones and the dollar store ones wich the ends do tend to break off, but i didnt get any noise problems, i had a clarion head unit then, 2v out put, 2 amp set up, i also made sure to keep the power wires ran opposite the audio side of the car.
yet oddly enough i got a $12 pr in my 4dr egend 16' and now after bout a yr n a half i am getting noise.
