Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 436 Registered: Aug-06 | ok on ebay there is boston g5 subs for $89 a piece woww is al li can say cuz that scheap for a boston and its g5, usually i see it like 300 for a g2 so would you guys buy those fo that price i dont think you cant beat that price and those subs are really clean and get pretty dammm loud from when i hear dthe g2's so the g5 are they better? they have more output wel i just sen them an dthere cheap but theres only 2 of them i think im gonna get em instead of teh type r alpines just cuz i know they will be just a slod and clean if not cleaner. any advice? |
Silver Member Username: MgbcsLincoln, Nebraska Post Number: 694 Registered: Dec-06 | Man that's a great deal. I would be weary tho cuz that's dirt cheap...kinda unreal. So just be careful. |
Silver Member Username: MgbcsLincoln, Nebraska Post Number: 695 Registered: Dec-06 | Those aren't subs man. Those are passive radiators. That's not what you want. You don't power them like a normal sub. They passive, so I think they use the air the other subs produce, or something like that. Either way, don't do it. http://cgi.ebay.com/Boston-Acoustics-GTR12-12-Passive-Radiator-for-G5-Sub_W0QQit emZ160099734765QQcategoryZ1498QQrdZ1QQssPageNameZWD1VQQcmdZViewItem |
Gold Member Username: IlluminatorUSA Post Number: 4972 Registered: Apr-05 | Nice job, Ben. :P That would be awful to buy passive radiators thinking they're subs...the seller should have been more clear about that. |
Silver Member Username: Dakangofkrunk16Earth Post Number: 360 Registered: Mar-07 | those things are made to be in same sealed encloser as a g5 and u gain 3-4 db's extra the seller was prolly tryin to trick people into thinkin they are g5's but g'5 dont look like that |
Silver Member Username: Dakangofkrunk16Earth Post Number: 361 Registered: Mar-07 | those things are made to be in same sealed encloser as a g5 and u gain 3-4 db's extra the seller was prolly tryin to trick people into thinkin they are g5's but g'5 dont look like that |
